Water in driver footwell
Drayday55
San Diego, CA, USA
Hey Guys. Does anyone know if the sunroof drain runs in the driver side pillar ? I have wet floor only at the driver side front. I'm checking the cowel tonight.
Welcome to the forum. Sorry to hear about your water problem. Good luck on repairing it.
Dram789
California
2020 explorer st
I had this issue in the passenger foot area. Ended up being the plastic along the battery cover that had warped. It was replaced under warranty
D
Drayday55
San Diego, CA, USA
I saw that above my battery the intake vent was open. Everything looks tight there. We have had the car since Feb 2020. This is the first leak. I think its either from a previous windshield replacement or a disconnected sunroof drain. I'll do some testing later to sort it out. I wanted to see if anyone knows if the roof drain runs down the driver a pillar.
roof panel drains.
If someone changed the battery or windshield it could be the improper reinstallation of the large plastic cowl trim at the base of the windshield allowing water to leak in by the cabin air filter and end up on the passenger floor area. Make sure the trim is tight against the whole length of the lower windshield edge. I believe there is a tiny weather strip between the bottom edge of the windshield and the upper edge of the large plastic cowl trim at the base of the windshield.
This ^^ I had my windshield replaced and started to get water on the passenger floor during heavy rain. Someone told me to check the cowl trim and make sure it was fully seated against the glass. I checked mine and sure enough, it wasn't seated properly, so I fixed that and the water has not returned. That was two years ago.
United States
Explorer ST
I had the same exact issue and solution to water in my passenger floor. Seems like a common problem, especially since it can be hard to tell if the cowl is fully snapped into place unless you hear/feel it happen.
Dgoebel57
Faribault, MN, USA
2020 Rapid Red ST
Ditto the last three above me, Windshield leak before and after trim corrected.jpg
Chicagoland
This is a DESIGN issue that will require regular maintenance cleaning. The issue is a BLOCKED drain relief bladder behind the wheel well splash shield. Plant debris lands on the front window cowl and makes its way BEHIND the splash shield and clogs everything up. This probably applies to all of the SIXTH gen Explorers.
Please read this thread below.
(3) Water Leak When It Rains | Page 2 | Explorer ST Forum
@Jimbo606666, You've commented on this in 5 different threads. We get it.
