I have done all my oil changes since owning and no leaks so far. Yes new drain plug is an interesting design.
Not sure if many members on here know this because I was not aware. There is a trend now (actually for years) that the oil change places and some dealers no longer pull the drain plug the use suction device and pull oil through dipstick tube.
My friend is a Gold Tech at Porsche and he said they have been doing this for years and he bought his own. When they checked to see if the suction device was getting all the oil out they found it actually did a better job then a oil pan plug pull & drip. Apparently this method is faster and no issues with drain plugs cross threading or leaking.
Im buying one for my next oil change, they are only $200....no more ramps or jack stands required.
Something like this
https://www.walmart.com/ip/Mityvac-...1?wmlspartner=wlpa&selectedSellerId=101264829
