So I’ve seen a couple people change the top bolt hole. But how? Is it drilled out. Using a die grinder. Changing top mounts completely. Camber bolts. I’m ok to just use them as is. But if there is a way to modify them that doesn’t create big problems then I’m down for a set. Also I’m not good on spring rate but is 12kg going to be too stiff and bouncy?
