How-To: Swap Bench 2nd row to Captains Chairs with Console
I checked ford accessories and the 16-19 console with white stitching is no longer available. The have with red for 425 and black for 550
BradLucky
Cleveland, OH
@bguild I have to thank you for your amazing write-up! You gave me the confidence to purchase a 2021 that just came off lease, even though it had captain's chairs when I needed a bench seat. To your point, I can confirm that swapping captain's chairs for the bench seat does work!
The downside - I just discovered - is that I got the bench from a 2020 XLT, which does not have the powered fold-down feature. In and of itself, I'm not too bothered by that, but, it lacks the wiring harness and control unit that provides power to the rear-folding seats. I did not realize this while I swapped all the seats, and now my 3rd row is stuck in the flat-down position.
So, I'm going to have to get the harnesses reconnected so I can put the 3rd row upright. And then, I need to decide how to proceed. I'll either remove the unit from my captain's chairs, or find what I need from a junkyard for a reasonable price. (I plan to put the captain's chairs back in someday when my kids have grown up enough that I don't need 7 seats.
I did manage to get the seats for only $213, so I can't complain about the cost. And the work only took me a few hours today.
Doesn't the XLT seat look different as far as the leather material and contrast stitching compared to the ST's?
Yes. Very different.
Illinois, USA
Nice write-up! Curious if the original bench had heated seats or not? Did you gain/lose this with the change over? Either way you did a hell of a job.
#26
XLT does not have heated seats. ST comes standard with them. You would lose it.
Socal
#27
I think his question was to OP's original bench seat, which they do come heated if equipped properly. Only the side one's not the middle one.
Yes that is why I said STs come standard with them. He had them originally.
Socal
#29
Yes and no, depends on the year, they were standard in 20 but became an option after for 21+
Not sure what year is OP's nor what options he had.
Nabuei
2022 Ford Explorer
#30
Question -- on 2022 Ford Explorer, can i purchase a used 2nd row center like this one u had (image attached) and squeeze it in between the 2 existing Captain chairs (with arm rests)?
I don't mind removing the arm rests -- just wanted to know if it's possible?
Thank you.
#31
Confused on what you are asking. Center console or center chair?
cjhesse
Moses lake
2023 Explorer
#32
Any suggestions where to find a 763kohm resistor?
chunley05
Ayer, MA
Ford Explorer
#33
So I have a bench seat and am looking to swap to Captains chairs. My question is, if I'm not looking to do a center console do I have to replace the PS seat or can I remove the 60 part of the 40/60 bench seat and just replace the LH side Captains chair?
#34
Nice writeup!
I was super annoyed that they finally upgraded the infotainment on the 2025's, but dropped the 2nd row bench as an option in ST's... and then even more annoyed to see it was still available in Canada!
Any Canadians have a 2025 ST w/ second row bench that want to trade for captain's chairs? :LOL:
Gastonia, NC
Switched 2nd Row Captains Chairs To Bench Seat on 2023 Explorer ST using your guidance. Thank you! It was a great write up. For those that need the part number to the bolts (my seats I bought on EBAY did not have the bolts with them) they are:
w505286 S439 -- These are the bigger bolts (the 15mm from OP) for the back of the middle seat. You will need two.
w709980 S439 -- These are the smaller front bolts (the 13mm from OP; the same that hold the captain's chairs down). You will need two for the front of the middle seat.
All of these are sold in sets of four from Ford and Ford dealers can usually get overnight delivery at no charge to you so long as you pick up from the Ford dealer.
One more thing. Don't be bothered if you are going to install the middle seat and see that the holes are not threaded. Don't worry--just screw the bolts in. I believe the threads are covered by a coating to protect them. When I screwed the bolt in, the threads appeared.
I let the seatbelt issue unaddressed, so I do NOT have a seatbelt indicator for the middle seat. But this doesn't bother me.
EXCELLENT WRITE UP THANK YOU!!!
New Orleans, Louisiana
And based on what I saw this is incorrect as the bench uses the same 4 bolt holes as the center console.
Based on this I am 100% sure that captains to bench is good to go. The issue is finding a bench from an ST. It's basically impossible from what I can tell.
Very few STs with bench option to begin with
after MONTHS I found literally one salvage 2020 ST bench with the heated option to go into mine. Taking out my captains. THANK YOU for this bro. This is an incredible lineup. Question for you - do I have to buy a new (salvage) carpet that’s cut for the bench seats or can I just find the holes and carefully cut on my existing carpet fitted for the captains? Lol
I’ll be ignoring the seat belt. 6 out of 7 alarms for unbuckling is good with me haha
#37
You should be able to locate the hole location. And then cut your carpet.
Awesome. Thanks! Now I wait. Wondering if I should pick up a new set of bolts in case they don’t send them. I mean I have the captains bolts obviously, but I’ll definitely need the center seat bolts.
#39
If I'm not mistaken, you will need 4 more bolts.
Mustang5L5
Massachusetts
2023 ST
#40
So I have bench seats in my '23 ST. On the fence about them but i'm discovering my youngest (7) likes to get into the 3rd row by jumping over the 2nd row seating.
What's the difference between the bench seat outer seats and the captains chairs? I've been trying to look at photos but are they the same seat other than the armrest and the lower bolstering/stitching design? I'm wondering if i could make due just pulling the middle seat and installing some temp carpeting and the cupholder console temporarily. At least then my youngest has a path to the rear seat.
Not sure i want to commit to the full captain chair swap yet as my oldest will be driving soon so there may not be a need to access the 3rd row, in which case I can leave those seats down fully and be fine with the bench.
