R2D2's 2022 ST - KISS Build
way2far
Tampa, FL.
Just read through your build thread to ultimately feel the gut punch with you at the end. Sorry that happened. Glad your wife is ok.
What vehicle did you end up with?
SackLunch
Lexington, KY
FORScan Change: Amber DRL with/without White DRL
Module : BdyCM - Body Control Module
Method: Easy click select
Additional Change : If you don't want the White DRL
Module : As-Built Modules BdyCM
Change : 726-42-01 x4x4 xxxx xxXX (original value was 0303 and new 0404)
Status : Working as programmed.
Note : Feature works when the vehicle is running, during day time (when DRL is supposed to work) and when Headlights are in Auto.
Pictures of Amber DRL working with and without White one
Question for the professionals. I was attempting to make this change and went to write the 404 change. A warning came up on FORScan about incorrect checksum of data entered. Should I just continue?
t_fiki
EMT
Colorado
I was wondering if anyone else has ran into the issue after changing somethings on Forscan. I will on occasion have the vehicle say "Language set to English" shortly after turning the vehicle on. I can't do anything that reproduces it and I have tried returning everything back to the original settings. Any advice would be greatly appreciated.
ssick92
You ever get this figured out? I ran into the same error message. I just hit yes and didn’t have any issues, but doesn’t look like the changes worked.
JRHII
EMT
New Jersey
Just did this today -- thank you made this very easy. I hated the white DRLs!
Str8bntST
FORScan Change: Remote Global Close
Method: Easy click select multiple options (not As-Built)
Status: Did not work
Plan: Need to try As-Built method, with multiple module changes, to figure out this one.
Plan Worked : 05/07/2023
Method: As-Built Modules BdyCM, DDM, PDM, AIPM
Status: Working successfully :cool:
Working : Now both front windows can be opened and closed from the remote.
Changes made (in green boxes) as below: Red boxes has the old values
So I did these, and my windows will barely move up or down. Even when holding the button they barely move. I returned all settings back to the stock settings, and still having the issue. Any ideas. Heeeelp. Lol
