Heat Fan Blower Motor Location
North Bergen, NJ, USA
2020 EXPLORER ST
Hello everyone. My Explorer blower motor is making a squeaky noise not all the time but sometimes. Where is the blower located so I can check it and see if some lube will fix it or something in it.
Thank you
Bowie, MD, USA
No clue. Just follow the squeak until it gets louder?
Desert South West
You have 2, one under the glove box passenger side , other passenger side rear cargo space.
S
2020 EXPLORER ST
The one I hear squeaking is by the passenger side.... Do I have to remove the whole glove box etc...
S
2020 EXPLORER ST
I don't wait until things get worse. I keep my car in tip top shape. I;m not like other that wait and wait and then they cry why it cost so much to get it fixed....
DaveG ST
Hurlock, MD, USA
Now that you mentioned this squeaking noise from the fan, I too have some squeaking that is noticable at fan speeds like 1 & 2. I turned the fan all the way up and back down, seems to have worked for the time being.
S
2020 EXPLORER ST
I have tried all of that. It happens at the same speeds yours dos it. I know it happens after an hour or so, like when the bearing on the shaft gets hot. That is why I want to remove the motor and se if it's possible to apply some lube like silicone etc... see what happens.
S
2020 EXPLORER ST
