Stock, varimax, and finally a reprogrammed Stewart EMD. Don’t remember the flow rate but it was huge, biggest available at the time that fit. Blew off fittings when I was initially testing and emptied the system in about 10 seconds
. Definitely helped initial iats and the ramp rate to heat soak was better but I would still boil the coolant after a 20 minute session, albeit in the boost most of the time.
As tmac mentioned. There is a reason most turbos run air to air. With an intake style blower you lose a lot of efficiency with the relatively small intercooler in the blower but the packaging can be significantly smaller. I don’t know if water/air with huge intercoolers would be good but I still think you lose a lots of efficiency with two intercoolers as mentioned above.
