looking at Nostrum HPFP & injectors but not sure if I should start at Stage 1 or go right to Stage 2...Nostrum website says Stage 2 if you're thinking of upgrading turbos or built engine. Stage 3 says for sure needs upgraded turbos etc.
I probably won't be upgrading turbos any time soon if ever....
sooooo my question is - can I still install Stage 2? or stick with Stage 1..?
here's a list of current modifications.. im running 94 octane..
-HR lowering springs
-Steeda adjustable rear sway bar
-Whipple Mega Cooler
-SPD Performance 3” catted downpipes
-Borla Atak cat back exhaust
-Asanti Black ABL-20 Aries Gloss Black 22x10.5 +35 5x114.3MM 72.6MM
-Michelin Pilot Super Sport 305/35/22
-Romik REC-B running boards
-Rotora Front 8-Piston/405x36mm 3D drilled discs w/white finish/red logo
-Rotora Rear 4-Piston 380x29mm 3D drilled discs w/white finish/red logo
-aFe Power Momentum GT cold air intake system w/pro 5R filters
-Lethal Performance 2.5” Mid Pipes
-Velossa Tech Ford Explorer ST BIG MOUTH Ram Air Intake Snorkel
-Houston Speed Freaks HSF Ford Explorer Full LED kit
-Diode Dynamics Stage Series DOT/SAE x2
-Diode Dynamics Stage Series Fog x2
-Steeda Explorer ST Subframe Bushing Support Kit
-aFe Ford Explorer ST V6 3.0L (tt) BladeRunner Aluminum Hot and Cold Charge Pipe Kit - Red
-Livernoise Motorsports 2020 Explorer ST Stage 4 tune
