Hi All,
Has anyone done a seamless wiring from inside the rear roof to the rear hatch? I'm trying to wire in the rear dash cam that's installed on the hatch window. The only clean way I can see that won't interrupt the seal is to use the same channel as the wiring in the rubber boot that's connecting the hatch electronics to the body. Problem is, I can't gracefully remove the boot from the oval hole without thinking I'm going to split it. I also can't pull the roof lining down far enough to see if there's a pathway to the boot hole. I don't want to rip the lining by pulling it down too far. I've removed the inside plastic panel going over the window but I guess I would have also remove the inside side panels to free the lining up a bit so I can pull it down further. Just wanted to make sure I was headed in the right direction before going any further. You can see the wire I'm working with dangling down from the upper seal on the right. Your thoughts?
Thanks!
Thanks!
