new 2023 ST Explorer and forscan and gauges
I picked up this gem today, it was built mar 2023 and has been sitting on the dealer lot since mid april or so 23
drive home a few thoughts
is there a FORSCAN change to get a boost gauge, or a real tach vice a line up the side of the speedo
and is there a forscan spreadsheet like we have for f150 and super duty trucks
test drive was hmmmm OMG this puppy shiits and gets even in ECO mode
Welcome and congrats. Unfortunately no way to get any info gauges on the cluster.
San Francisco
There is a forscan spreadsheet thread. There's one for A.S.S. disabling too.
We know where youre at - tach only in sport mode is DUMB, and no boost gauge at all is freakin RIDICULOUS.
Somehow Ford made a sport vehicle and decided not to be fully sporty. :ROFLMAO:
P
Link to the sheet
I found an old one.but it's not very up to date
O found setting to put a sliding tach on left side of speedometer.
But no temp, no Trans temp, no boost
Sort of strange.
I need to look at an aviator as built to see what it has once I download load the as built files today
Hyins
Santa Clara
Link to the sheet
Sort of strange.
Livnitup's U625 Explorer as-built spreadsheets
https://docs.google.com/spreadsheets/d/14sSYEErM-6OjVQ3CIukfkgBqYkDE2w8imywaNF8VJF8/edit?usp=sharing
you can't get boost gauge because the IPC UI doesn't support this unless you replace a Focus ST's IPC
P
Somalia
P
ipc is instrument panel cluster
UI is ???
but the boost is in there, as its on the lincoln aviator so its loaded we just have to go through the data line by line to see if we can enable it
the spreadsheet above is the one i am working on and updated the other day for common.
It might not be enabled in the vehicle firmware ..but it's early yet for me so I am digging in like my f150 to exploit anything we c a n. To mske our driving experience as good as we can get
SparWars
Looking for the number of flashes line for lane changing. Should be on the common list. 3 flashes is standard. I want 5 or 7 for trailering.
Which module?
There’s no boost gauge to enable. People have looked for years.
Nightshade
Firefighter
Alberta, Canada
2024 Ford Explorer ST
Well well well if it isn't my 14th gen F-150 buddy haha!
If you need the help, let me know. I've discovered a few FORScan changes that work on the Explorer ST. Already well ahead into it! ;)
UI is ???
P
Hey stranger
I sent you a note at f150 site
Socal
Wanna share with the rest of the forum? lol
P
f150 14th gen web site
we are all in the mess together as it were...or is that as it is?? what is is?:eek::eek::eek::eek:
P
Thread Starter #17
yep... people would be amazed at what we solve at the 14th gen forum.. collaboration is key. by we, i mean almost everyone there.(y)
i have not seen the FORD bot here though??:eek::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Hassa
New Westminster BC
Thank you for all your help here. I’m really trying to find a way to set a different drive mode to come on when started. Currently defaults to normal, but many here would love to have it default to Sport or Eco
Sadly it is impossible to do so.
Nightshade
Firefighter
Alberta, Canada
You're welcome! Like @2020FordRaptor said, I still haven't found the work around for that even in the 2021+ F-150s.. yet. Rest assured I'm still looking into this.
