I have seen some debate, and have a couple of questions:
1) What is the factory thermostat on the '20 Explorer ST rated for? (180º or is it confirmed higher?)
2) If one has the vehicle factory tuned, is it still worth swapping out for an SPD 180º t-stat?
3) If running factory, will you get an engine code after swapping thermostats?
4) What are the downsides (if any) to swapping thermostats?
I started this because I didn't want to take over UNBROKEN's thread (which I really dig). I did search these forums and elsewhere and didn't find a ton of concrete info.
