try this
double check AGAIN you made the correct changes
Bambi Fog Light ModeBCM726-39-02 xxx0 xxxx xxx Fog lights remain on with high beams activated, once button is pressed.
also out switch cycle fogs to off each time light control knob is turned or used, and each time you start the vehicle the fogs by default in the switch are OFF
so you have to press the fog button each time, then it stays that setting until next key cycle
i am looking at how to keep them set like we can do in the f150, its the same switch.
also key off then on again in forscan, rest apim
then disconnect and turn off key, open door and wait 30 seconds to let car turn off, then turn key on and select fogs then hit brights and go see if they are on now
