Phoenix, AZ USA
TYVM.. The lowering springs are being installed as I write.
I love this ST and its gorgeous Rapid Red Met. color that I bought a new Mustang GT Premium in the same color!
2024Apr15_DSF0938_Front corner Bursons_1500w.jpg 2024Apr15_DSF0939_LR Bursons_1500w.jpg 2024Apr15_DSF0938_Front corner Bursons_1500w.jpg 2024Apr15_DSF0939_LR Bursons_1500w.jpg
Have ordered for this Mustang a set of 19" versions of the wheels on the ST.
Suprawill1
View attachment 22836 View attachment 22837 View attachment 22836 View attachment 22837
Nice job! Although I think the current wheels on the GT are pretty sick too! :)
I always liked the oval tips on the Aviators…so I upsized that idea and did some welding. IMG_3491.jpeg
I always liked the oval tips on the Aviators…so I upsized that idea and did some welding. View attachment 22869
I noticed today the tips are round,,,,but the pipes turn down before the end of pipe..guess to prevent leg burns
Like the 15 16 and 17 expeditions
I put on the ford pem splash guards today
Hmm noticed the skid plate was not there. Guess Monday it goes on order..pretty dumb leaving a plastic pan thst close to the ground naked. We get lots of debris on roads here.
There’s not a cover for the trans pan.
Today I installed the steeda rear sway bar, steeda vertical link inserts, and the eibach rear springs. I discovered that if you remove the vertical link, the lower control arm can be pried down enough to pop out the rear springs pretty easy, no need to drop the rear subframe or loosen the subframe bolts. My old fat ass is worn out from getting up and down from the creeper about a 100 times today so tomorrow I'll install the steeda pinion support bushings and the eibach front springs.
Ceramic coating done.
Suprawill1
Looks good! I like your stripes!
Recently installed Magma "pro-series" front brake pads. 200 miles in, great pads for non street pack!
(Amazon part: PSD2230C)
BigAnt75
Haslet, TX, USA
Just got done data logging my first revision of the ZFG 93 Performance tune and WOW! what a difference in just the baseline tune!! Gotta give it to Adam and company!! Great company and even better product! Excited to see what else this thing can do!
Warpath
Springfield
Finally got around to installing my Whipple intercooler, AFE hot side piping and momentum intake, Fenfab charge pipe, Ford black badges and UPR catch can.
I did one hell of a hard project,
Refilled the washer fluid reservoir
very lazy day here
View attachment 23133 View attachment 23134
Is there any noticable difference in sound after installing the aFe intake system? I was thinking about doing the complete system as well (everything from the CAI to the charge pipe) but with such minimal gains I had a hard time pulling the trigger. From everything I've read, the stock system flows just fine unless you upgrade the turbos and start getting over 600 Hp. But now I'm hearing the change in sound is awesome. I've never had a CAI set-up make any sound so I'm guessing it has to do with the turbos. I'm just curious to hear how much different it sounds.
