50-60k: I'd do spark plugs, front differential oil, transfer case oil, rear differential oil, transmission drain and fill, brake bleed if not done in a while.
Transmission fluid should be top of your list. Then just spark plugs if needed and if you want to go all the way transfer case fluid, and front and rear diff fluids although I don’t think they are that important.
