Hi All,
I actually appreciate this feature if it does indeed save fuel but there's one instance where it's unwarranted.
After doing a hard pull, I came up to a light and the first thing it did was shut down which is a no no after high boost. These turbos are supposed to cool down after peaking out and I'm surprised that with all the programming these STs have, that isn't taken into consideration. In a case where you're not expecting to do a hard pull, there may not be enough time to disable the autostop feature or even think about it before you come to a complete stop. I'd hate to disable the feature every time I drive predicated on the fact that I "may" have to step on it, climb a steep hill or some other tasking job for the turbos.
Your thoughts?
Your thoughts?
- Show All
