Did the Lincoln screen swap
tbattista
Does the screen have a slight tilt towards the driver?
bender953
Columbus, OH, USA
Thread Starter #42
reached out to Haven3DDesign and he said they are making more and will be available again soon hopefully
bender953
Columbus, OH, USA
Thread Starter #43
because you have to make brackets to connect the screen you can make it tilt if you want. The 3 mounting points on the Lincoln screen don't reach far enough to the spots on the dash so people are zip-stripping the screen in or making custom metal pieces to bridge the gap
Minneapolis, MN, USA
#44
Nice to see some trim can be had to clean up the bottom section. I was able to buy a screen from car-parts.com and will start working on this in a few weeks after i return from spring break. I envision the Lincoln screen could potentially sit a little lower to where it would be inset slightly into the radio bezel at the bottom that wraps down the radio controls up to the level that it does in the Lincoln, so the bottom section up to where the chrome trim on the sides starts could be inset. It would require some very clean cutting into that radio bezel trim piece, and would be slightly lower than some of these shown, but if it works, it could look pretty clean. Of course i haven't pulled mine off yet to see if it would align/mount lower than what has been done so far, and how clean that would look from the back, but worth a shot.
Bear, DE, USA
#46
Yes there is no issue mounting it lower you can have it literally resting on the dash above the hazards if you want. All depends on how you want it mounted.
Jorgimbo
miami
2020 Ford Explorer Platinum
#47
have you tried to get the climate controls on the screen using forscan now that is landscape and not portrait?
Aron03
Miami
My screen did not come with the vanity panel on the back and the junk yard no longer has it, the part is $100 from Lincoln......
Whats the part number from Lincoln for that back piece?
Amsterdam
Ford Explorer ST PHEV MY22
#49
Would it be possible to pin a complete lists of parts needed for this swap?
Toronto, Ontario, Canada
#51
Anybody got anything new to add to this thread ie part # screenshots of forscan ?
bender953
Columbus, OH, USA
Thread Starter #52
Finished my install. I switched to the 8" trim panels and used a square aluminum tube to make the brackets to mount it so it would sit higher.
2020+ LINCOLN AVIATOR DASHBOARD INFO DISPLAY SCREEN LC5T18B955UH OEM
2020-2023 FORD EXPLORER DASH CENTER AIR VENT GRILLE TRIM LB5B19F648BC
2020-2023 FORD EXPLORER STORAGE TRAY LB5Z7813546AC
Forscan was easy. In the APIM change 'Brand' to "Lincoln" and 'Visual Design Variant' to "Lincoln My20 10in"
There is a youtube video showing how to change from the 8" to the 10" ST screen for reference on how the panels install
ST-WOOO
St Augustine FL
will this work wether we currently have the vertical or horizontal screen ?
Would you post up forscsn codes
Apim xxxx. Xxxx xxxx
Or did you go in the easy mode
And if you stay with vertical screen...how does lincoln setting change layout
Bear, DE, USA
#57
It’s in easy mode, and with the vertical screen the Lincoln mode won’t work.
Thank you
rcflyer
Rochester
#59
Got my screen from eBay and mounted it today with my custom fabricated parts. I ordered the lower trim piece from Etsy and it'll be here next month. Has anybody come up with the back vanity cover part number? My parts guy can't find it. He thinks it's part of the screen. I'll post pictures if anybody is interested. I switched from 10.1 portrait (factory installed) to 8" landscape and now 10.1" Lincoln Landscape.I didn't like any of them until I put the Lincoln screen in. I love this setup. Thanks to everyone who has contributed to this project.
What did you search on Ebay for the Screen? Still looking for a screen
