Put on another 300 miles pulling our airstream . Was able to hit a Cat scale going out . Weights were front axle :2660 rear axle :3140 and trailer 6520. Steered very well on curves ,pulled up on ramps very well .transmission and engine temps never moved,and gas mileage was11.5 on the hotter day and 12 on the cooler return trip drive. A very slight wiggle but adjusted the sway control bars and seems better .still dialing in the hitch /weight distribution set up but far better than my old expedition (with HD tow package ) . Yes the plug is lower left under the dash ( there is a write up on this forum on installing that is helpful) ,used a Tekonsha prodigy brake controller ,camco ez lift 1000 pound hitch ,with 2 husky sway control bars .the drop shank is made special for Can Am rv ,gets the ball right up close to the bumper and they performed the hitch receiver reinforcement .hope this helps
