Started hearing a rattling noise coming from passenger side when driving on highway. Come to find out it’s the undercarriage that’s coming slightly loose. Has anyone had this problem and what’s the fix? Looks like one of the bolts may have came loose as well and I cannot tighten.
If your talking about the underbody panels yes, I had one nut come completely off on the passenger side. Could see the panel hanging down. Found a nut/washer that fit and fixed it.
I just removed it. With the Thermal Exhaust, there's nothing remotely close to the heat shields. I may reinstall it before winter to try to keep salt and snow of the floor pans.
yup, get some stainless fender washers and M6 nuts. There is a section that is cut inward (for whatever reason), that flaps even with the new hardware. You can get creative with some zip ties to fasten it to the holes above.
Just got mine fixed as it was the passenger side that was loose. Dealer took care of it and tightened everything back up and added the push pin that was loose. Only charged $35 as it took half an hour to take all off and redo. Great news is my dealer took care of the charge and ended up being free. Great service!
