LED Turn Signal Bulbs
Delafield, WI, USA
I'm looking to upgrade the rear turn signal bulbs to LED since I have tinted my taillights. What bulbs are people using that I do NOT have hyper-flash? I do not have Forscan to get around it. Just looking for plug-in-play without any messing around. IMG_3082.jpg
Columbus, OH, USA
I use these, work great no issues. You can also use regular bulbs and disable the hyper flash with forscan, but these are plug and play. Screenshot_20200924-150532_Amazon Shopping.jpg
Nelson6655
Delafield, WI, USA
JohnE
Vancouver, WA, USA
I use these, work great no issues. You can also use regular bulbs and disable the hyper flash with forscan, but these are plug and play. View attachment 2051
Do you have the specs for the regular LED bulb without the resistor? I have Forscan and can eliminate hyper flash.
Baldwin Harbor, NY, USA
I just installed these and they fit and work just fine. No Forscan effort needed.
I'm curious as to what people use for LED reverse light and license plate light bulbs?
Nelson6655
Nelson6655
Delafield, WI, USA
F4EA100C-A2EE-4EF7-9070-691BE9350B0B.png 0C4E4CB2-1553-40AF-A044-47C0C8160A85.png
Installed "these" meaning what? I think you forgot your pic or link. As far as reverse and license plate bulbs, see my pics above.
Sorry, I didn't realize the OP was not showing what I installed. However Post #2 refers to the SyneticUSA signal bulbs. That's what I installed.
https://www.amazon.com/gp/product/B07J5TJV5P/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Regardless of what the page says, it does fit the Ford Explorer. There is plenty of room behind the taillight for the second plug and the resistor unit or whatever it is. The only weird thing was that although the bulb blinked perfectly it took about 30 seconds for the indicator lights in the dash to adjust themselves. No hyper flash at all.
JohnE
Vancouver, WA, USA
I installed these and I’m totally happy with them. Turned off hyper flash with Forscan so no need for resistors.
Turn signals
Back up
License plate
Nelson6655
Nelson6655
Delafield, WI, USA
clbh2p
Loudon, TN, USA
clbh2p
Loudon, TN, USA
I'm looking to upgrade the rear turn signal bulbs to LED since I have tinted my taillights. What bulbs are people using that I do NOT have hyper-flash? I do not have Forscan to get around it. Just looking for plug-in-play without any messing around. View attachment 2050
Just curious are those the original exhaust tips or aftermarket?
Nelson6655
Delafield, WI, USA
Bear, DE, USA
Anyone know what I need to change in Forscan to disable hyper flash?
Airizona
It's also one of the easy configs, I just don't remember the exact wording for that. I think it's something along the lines of Turn Signal LED though.
Bear, DE, USA
rear bulb outage “disable” in Easy config! Found it thanks!!
Bear, DE, USA
