Ebay IC
Jessup, MD, USA
#41
Not my pic, but looks like I won't be the first to install this.
Another person said they've had it for a few months with a tune, no issues. Their dragy was in the usual expected range.
I just found that I have a bad driver CV axle and the front axle disconnect actuator leak. Intercooler install will have to wait until those are sorted out at the dealer in May...
Jessup, MD, USA
#42
I finally installed the ebay IC today.
It went pretty smoothly, nothing unusual for an IC install on this car. The only hiccup I had was that the supplied bolt for the MAP sensor was too short. I had a feeling that would happen when I compared the supplied hardware to the Mishimoto hardware. A quick trip to Lowes took care of that.
I am using Torque Pro to watch charge air temps. Can anyone confirm if I'm using the right PIDs? I believe Intake is the temp of the air after the filter, and IAT2 is the air temp after the intercooler.
This screenshot was immediately after letting off from a WOT pull to redline.
I think I can feel a difference in the car. It pulls more consistently and it feels like there is a little more oomph up top too.
Jessup, MD, USA
#44
Just an update now that it's very hot out:
Intercooler seems to be doing its job. I picked up a Cobb Accessport and have started tuning with Alan Jackson at Edgeautosport. Here's a datalog I took during a hot summer evening in the 80s, charge air temps were in the 90s during a pull.
https://datazap.me/u/jwuonog/explorer-st-5th-gear-pull?log=0&data=4-7
cowanbw
2023 ST
#45
Have any more data you can share? I’m currently looking at these ICs and trying to decide if eBay is worth it. I’ve had several other cars where they worked out great so if I can save a few hundred bucks I’d be happy.
Just get the CV Fab…do your car a favor.
Jessup, MD, USA
#47
I'll upload some more datalogs later today.
Jessup, MD, USA
#49
datazap.me | jwuonog | Explorer ST Quarter Mile 12.6
Here is a datalog of a Dragy run. I had just done a few Dragy runs prior to this one. It was 77 degrees, and 73.7% humidity. (I think humidity affects the IC's performance?)
You can click on different items in that link to toggle them. Look at Charge Air Temp and Engine RPM. You can see that the temps slowly climb during the run.
I think the brand name ones do a better job of keeping temps down over the course of a several-gear pull. My sample size is small, but I do think the other ICs perform better. My tuner has a CVFAB and I think his was doing a bit better over a quarter mile run.
If anyone has any datalogs with other intercoolers, that would be a helpful comparison. You can upload them to datazap.me.
Would I recommend it? I'd say it depends on your use case and your budget. It's is still a huge improvement over stock, and for my use case (wife's daily), I'm fine with it for now.
In my experience, the IC keeps charge temps about 10-15 degrees above ambient, except for very humid and hot days, it climbed a little higher. I haven't had it in colder weather yet.
Dominican Republic
Ford Explorer ST 2021
#51
Anything other than the factory one is an improvement. I would like to see the datalogs of the other brands.
#52
Jessup, MD, USA
#53
What program are you using to datalog?
Before I was tuned, I was using an OBDII Bluetooth adapter and using Torque Pro.
Now I'm using a Cobb Accessport, then I upload the log to datazap.me
