Lowering Springs Pros and Cons
Green S/T
IN
Thanks. No towing for me. Have Tahoe Limited and Q7 for that
#83
You forgot Eibachs
Eibachs reputation proceeds them but they just were released so they slipped my mind.
SmittysST
SOCAL
2023 FORD Explorer ST
#84
Im looking at the Eibachs, anyone have them and can offer any pros and cons here?
Edgeybra
Los Angeles, CA, USA
#85
I just received my eibach springs today. Going to attempt to install them in my garage soon.
Who did you order from? I bought it from Lethal a few weeks ago and they are on backorder until the end of the month (or so they say)!
Somalia
#88
how are the Eibachs, I want lower and the rake on my car
Somalia
#91
can springs be powder coated or does the flexing or heat involved in the process make it not work
#92
I think people have done it quite a few times.
Just installed H&R's on a new 2023 ST a few weeks ago. The rears ended up sitting about 3/4" higher than the fronts. I like a little rake. IMG_9049.JPG
#94
Just installed H&R's on a new 2023 ST a few weeks ago. The rears ended up sitting about 3/4" higher than the fronts. I like a little rake. View attachment 22879
Hopefully they settle because the rear is a little high for H&Rs. Looks great either way though.
hfrog355
Louisiana
I've been reading a ton of threads lately about various enhancements and I've seen more than once mention of Steeda products rusting - primarily springs and the sway bar. Does anyone know if Steeda has done anything to rectify this issue? I've seen mentioned that they have a good record of replacing parts that corrode quickly, but I'd much rather them apply a coating that doesn't rust as easily.
#96
No, there has been no change in how they cost their products.
Conjecture? I noticed the springs are now coded with a date and a version. There is a slight difference in the coiling but not sure if this represents a change in design or manufacturer or normal production variation.
#98
I might be wrong here but I think that they revised the spring design.
