- Messages
- 40
- Reactions
- 56
- Points
- 12
- Location
- Pennsylvania
- Vehicle
- 17 Explorer, 20 Transit, 24 F150, 25 Explorer ST
Hi everyone! First time posting on this forum.
I just installed the Wired Keyless Entry Keypad on my wifes 2025 Explorer ST. Part # LB5Z7820555E I have went through the steps in FORScan to program, but was unsuccessful.
I am running the 2.4.14 Beta version.
Here are the steps I took to program BdyCM and APIM in the plain english menus.
I am using the vLinker FS USB OBDII Adapter on Windows 10 Laptop.
1. Enabled Keypad in BdyCM (Hardware enabled)
2. Enabled Keypad in APIM successfully.
3. Performed BdyCM Local Interconnect Network New Module Calibration successfully.
4. I retrieved the factory code by cycling ignition and swapping the 2 keys and it displayed on the instrument panel.
5. The option for adding a personalized code now appears in the settings menu. I confirmed the factory code was correct by setting a personal code in vehicle settings.
My issue is the keypad does not respond. It does not lock the vehicle by pressing 7/8 and 9/0 or unlock with the factory code and personal code. Keypad illuminates when the numbers are swiped and the red LED indicator at the top of the keypad lights up when each number is pushed. I also tried "LIN Enabled" in BdyCM and that did not work either. Furthermore, since the programming was done in the plain English menus, I verified the correct addresses were programmed with the correct values in the As Built menus by cross referencing with the most recent spreadsheet.
Since this is a 2025 model, I am wondering if something else is required. According to my 2025 Explorer Workshop manual, it says to use FDRS and run the LIN New Module Calibration after enabling. I also looked through the entire spreadsheet and the BdyCM and APIM are the only modules that list any Keypad options.
Any idea how we can get that keypad working? I appreciate any help I can get!
