Seattle, WA
Louisiana
Have had my ST for almost 2 weeks now. Baby steps:
- TuxMat floor liners
- 3D Kagu cargo liner
- J&L Catch can
- Some black valve stem caps (showed up with green plastic and one was missing...¯\_(ツ)_/¯ )
- The aluminum ST pedal covers
Still researching parts, but have a list of ideas going. Probably going to do some suspension pieces this fall along with the differential brace and move into power modifications around the new year.
In the meantime, having a blast driving this thing! First time I've had a fun car since selling my 370Z a little over 10 years ago.
Installed a Diode Dynamics Brakehitch light and K&N air filter.
Probably going to move to some suspension parts next. Looking at the subframe lockout kit and sway bar.
Is there a material difference between the Steeda and FenFAB subframe kits? Steeda looks part dependent based on which subframe you wound up with, whereas FenFAB is a one size fits all affair.
Seattle, WA
AWR installed today! But also… I don’t think this is anything… but check out my sub frame diff bolt.. looks… greasy? But no fluid/drips anything like that.. anyone know what this is? I already have new bolt and JXB bushing. That will be installed next week when I can get an impact under there. But yeah, look how “clean it looks around the bushing.. it’s odd to me.
Any insight is greatly appreciated.
Suprawill1
Replaced a leaking trans cooler today. Turned a quoted $800 cost down to $255.
It was installed by a guy who charged me only $127 labor when everyone else wanted $500.
Ford stealership wanted $305 for the part but got it at Miracle Ford Parts for $128.
Don't know how they figure on charging $500 for 3 bolts and 2 rubber fluid lines.
Just more freakin' gouging.
Sumner County TN
2025 Ford Explorer ST 400a
Had a hill assist failure. Used FDRS to update ABS module that required new firmware. Problem cleared and all normal. Then used Forscan to change one setting to create bambi mode…
Derry, NH
Finally got around to installing the Steeda rear diff pinion bushings. Definitely wasn’t easy pulling out the old bushings. For anyone doing this, take out the rear bolt/s from your diff after you get the lower bushings removed. The diff won’t drop down enough to get the top bushings out. Also, if you have the Steeda rear diff brace then you will need to remove the 2 long bolts and the back part of the brace to allow the diff to drop.
Polizi212
Installed my tuf skinz inserts that I had made in Reflective black, for the lift gate and the rocker panels. I think they look amazing. Just my opinion. A before and after shot, I think they look just subdued enough and will pop at night.
Loaded05
texas
I added the spacers that finally got delivered. 1-1/4" in front and 1-1/2" in back.
Coffeehouse
Firefighter
Buffalo NY
WeatherTech front/pass mats and cargo mat. Ordered the fenfab ecu black cover with red back plate.
Suprawill1
Installed the red inserts. I’ve had them since last December but was on the fence about them. But now that they’re on, I like them!
Did the same last year and I think they stand out nicely with this color scheme. Matches the "ST", the tail lights and the calipers.
Coffeehouse
Firefighter
Buffalo NY
Did these a few days ago.
Loaded05
texas
Installed an ethanol sensor and connected it to my P3 gauge.
Loaded05
texas
Does your P3 gauge show trans fluid temp?
Yes, it shows boost, coolant temp, fuel temp, ethanol %, trans temp, throttle angle, AFR, RPM, timing, EGT, IAT, temp at MAF, temp after intercooler, battery voltage & accel, decel timers. It will display only one reading at a time, and will forget the max for each reading when you switch to another.
Front end is off of the new 25' ST. You are looking at the very near future home of a hidded behind the grille, 22" dual row light bar!
Suprawill1
