Fuel Inlet Issue
DaveG ST
Hurlock, MD, USA
Need some advice for possible fuel inlet issue. Check engine light came on about a week ago and FordPass indicated it was an emissions issue and recommended checking the the fuel inlet. It explains that the typical fix is to put the fuel funnel in and out of the fuel inlet a few times. I did this and I cleared the code with a scanner. Today, the light came back on and FordPass is indicating the same issue. Anyone have a possible resolution to this issue?
Check valve at fuel inlet is fluttering or not maintaining seal.
Which sets off dtcs
Like aloose gas cap
Look at the seal see if it's damaged
What was the DTC specifically?
Chicago
2020 Explorer St
Its the evap valve thing i got it too code p0456 i have the part in my car i havent gotten around to replacing it.
DaveG ST
DaveG ST
Hurlock, MD, USA
Yes, it was as ehouse98 mentioned, P0456.
Chicago
2020 Explorer St
Dave i tagged you on another thread with the part you need.
DaveG ST
DaveG ST
Hurlock, MD, USA
Yes, thank you. I reviewed that thread and it seems that was for a different code though.
Chicago
2020 Explorer St
its not you will get both codes eventually one is for small evap leak the other is for evap leak
DaveG ST
DaveG ST
Hurlock, MD, USA
Okay, so even FordPass indicates that this is an emissions issue. I am at 79K miles and ask dealer to fix under the 80k emissions warranty. This dealer has come through for me before, but told me today that I had to pay out pocket, about $600. I said no thanks.
Pyro_1284
Whittier Ca
Yeah it’s Evap purge valve, did it myself. A bit of a pain but possible. Fix the code and issue.
