Updated FORScan sheet for 2020+ Ford Explorer (All Trims)
#43
Start up chime? Should be available in the IPC easy way module, but can double check this week for you and get in touch!
I've been looking to get rid of the Start Up and Alarm On Exit, Do-do-Do, chimes but have been unsuccessful. I looked in the IPC and found several chimes but those are not there. I thought I read somewhere that they are located in the APIM so I looked there and found some chimes at 7D0-08-01 but I'm not sure if this is it. Right now the second digit is 0 which indicates all chimes are off but obviously they are not. Do you think you can look into this? I'm sure there are other who would like to turn off these chimes. Thank you!
FL
#44
I did both of those earlier this week on my 2024 using the instructions in these two posts.
Double Horn Honk on Leaving Cabin
https://www.explorerst.org/threads/r2d2s-2022-st-kiss-build.5210/post-72450
Disable three start-up chimes
https://www.explorerst.org/threads/r2d2s-2022-st-kiss-build.5210/post-72956
#45
First off, thank you for posting this! However, two things: one is that the Double Honk On Leaving Cabin and the Do-do-Do chimes when you open the door with the vehicle running are different. I've already disabled the Double Honk. The second thing is in the second post. Where it says "Method" it shows only the second digit changed to a two but down below in the green and red boxes the fourth digit is changed from a three to a five. Which is correct?
I can look
Yours is what year
yes the 7DO-08-01 X0 xx is correct
you did the bcm change as well 726-63-02 xxx0
however i looked at my asbuilts and they dont reflect my vehicle
my first 4 digits are 4007
which indicates power mirrors Off, , 0 which turns off the chimes on door if engine is on,
and the next line moon light mode off? ad TPMS off, which is wrong as my TPMS is ON
i need to go look or listen to what my explorer does
FL
#47
I only changed the second digit to a 2 and it updated the fourth digit after writing it. I think the fourth digit is a checksum.
The 3 do do do start up disabled
Shoukd also kill the door open do do do
Good catch
