Yellow fogs
gchris310
Los Angeles
2021 Ford Explorer ST
Love the look of mine and also have them set to run as DRL's along with the White LEDs. Enabled with Forscan.
23 Explorer ST
For the life of me I cannot understand how the lamin x fogs work. Been sitting here for an hour trying to figure out how they are supposed to work.
What do you mean “how they work”?
Are you asking how to install the film over the light?
The yellow only works with certain colors. I did the precut and they just laided right on and then I trimmer the excess. I didn't even need heat. Maybe because it was so freaking hot that day.
Rick4345
Illinois
2024 Ford Explorer St-Line
I think he's talking about which piece goes to which side. To me, the side with what I call, the larger curve goes to the outside. I believe this is the correct orientation. The picture with both of them has my cat on what would be the driver's side if I'm correct....... If I'm wrong, let me know. I'm just as confused as anyone else!! Fog Light Film Install 1.JPG Fog Light Film Install 2.JPG Fog Light Film Install.JPG
