P-0455 - Evaporative Emission Control (EVAP) system, gross leak.
Drsobczakst
Chicago
All,
I recently started getting the P-0455 - Evaporative Emission Control (EVAP) system, gross leak.
I am dropping it off Monday but i wanted to see what everyone else's outcome has been with this CEL and dealerships?
I tried cleaning the filler area myself and the inner seal was a little dirty but nothing that would make me think that was the issue.
I do have a hard start from time to time as well just to add info.
Thanks!
Charlotte
2024 Explorer ST
I wouldn't doubt if its the evap purge valve. There's other threads with other codes this thing can cause.
powerboatr
Purge valves have issues
And if the evap canister got flooded with fuel vice vapors. It takes awhile to purge out
Running till near empty
Hot day, pumping cold fuel in a high rate, can cause an issue and over filling...can easily cause fuel vice vapors to get in canister
Iirc. On other vehicles
Coasting , no throttle in gear at mid level rpm will force a purge ..but nor sure about the explorer ...
New Hampshire
Like others stated its probably the purge valve, I just replaced mine a few days ago, little pain in the ass to do but not too bad.
D
Drsobczakst
Chicago
It was the Purge Valve and the canister was full of trash. they replaced the valve and flushed the canister however they do that...
powerboatr
Turn it upside down
Did they show you the trash?
I would curious as to the nature of trash,
Plastics, leaves, etc
D
Drsobczakst
Chicago
I picked it up after hours so i wasnt able to ask. My buddy who works there is on vacation so ill have him look into it when he gets back.
