Mr. Unbroken, did you replace the silver surround on the steering wheel with the gloss black from 2021+? I saw that you replaced the matte black with silver a long time ago.
is it hard to remove? I’d like to do the gloss
Thread Starter #1,222
I didn’t but I’ve had the wheel apart a few times to recover it. The trim is super easy to get off once the wheel is off so swapping it would also be easy.
Thread Starter #1,223
Winter rebuild things are showing up.
I had Acoustic Elegance build these subs for me. They’re IB15AU’s and I’ll be cutting the tire well out to vent them outside the car.
Also swapping amps to a pair of Mosconi Pro 5/30’s to have one amp per side of the car. Should make for a good time. IMG_5289.jpeg IMG_5261.jpeg
Also swapping amps to a pair of Mosconi Pro 5/30’s to have one amp per side of the car. Should make for a good time. View attachment 27052 View attachment 27057
Wow, nice little upgrade there
Killer upgrade! What’s the purpose of venting outside the car?
Thread Starter #1,226
They will be in an infinite baffle configuration like my midbass are. There is no enclosure.
