Auto Up Windows
I was talking with someone who has a non-ST Explorer and he mentioned how his windows all go up automatically when he double presses the lock button on the key. My ST doesn’t do this! I’m jealous!
Sacramento, CA, USA
Our '21 will roll down the front two windows if you double tap the unlock button and hold it on the second tap. Maybe try double tap and hold the lock button down on the second tap to see if they roll up. If not maybe it can be enabled with forescan if someones else wants to chime in.
This was a feature on my 2013 Lincoln MKZ. i could hold down unlock to pop the sunroof and lower all 4 windows with the one touch. Then I could hold down the lock to close all 4 windows and close the sunroof and sunshade! I had the panoramic (HUGE) one piece class roof.
I was checking out the ForScan spreadsheet. What is the Remote Global Window Open/Close?
I don't think my vehicle is equipt for this. The rear windows don't even have the auto down or up function like the front windows have.
Boyd
Tennessee
I dont think any Ex's have auto up or down on the rear windows.
In your Advanced Settings, there may already be an Open Window check box. If updating ForScan, when doing the IPC change, it will add a Close Window checkbox.
Global is available in ForScan, but it requires several changes. PDM, DDM, BCM, IPC. All available in Livinitup's spreadsheet. Front windows is available for all trim levels, rear windows may or may not work due to child safety liabilities. Dont want to unknowingly crush the kids hands or give them access to the asphalt slide...
I’ve done a lot of research into this and can’t find anything. I can’t find this option on any Explorer. Next time I see him I am going to find out what MY and trim level he has. I’m thinking this is an option added by an aftermarket alarm system. I don’t think it’s anything that comes as a factory option or can be programmed.
As I suspected it’s an aftermarket alarm system and it only works on the front windows.
Hyins
Santa Clara
BCM 726-11-01 xxxx xxxx x1-- global close remote enable
BCM 726-11-02 x0xx xxxx xx-- global close single press mode, or set to 1 for press and hold
BCM 726-22-01 x1x1 x1x1 x1-- global close customer settings enable
BCM 726-27-02 xxxx x1xx xx-- global close feature list to BCM init value
DDM/PDM 740/741-02-08 xxxx xxxx x1-- global close enable
DDM/PDM 740/741-04-04 xxx0 xxxx xx-- Rear window present
+ additional IPC & APIM settings
South Carolina
My auto window down/up quit working one time and I tried this and it worked:
There is no auto for back windows
Bridgewater, New Jersey
What isn't available and is an aftermarket??? Just opening the 2 windows or opening all 4?? I saw a post on this and just tried it once and the front windows opened ! I was shocked. I haven't tried to mess with anything else yet...
Thread Starter #13
If the windows are down and you lock the vehicle with the key phob, they will all close automatically.
Cool ! I didnt know that one .. They sell you are car and let you find all the hidden gems ! LOL....
R_lanzo
Unites States
01 Explorer ST
You seem the most invested in this topic. Have you come to a decisive conclusion? I plan on doing the usual Forscan changes and was hoping for Global windows up but the verdict seems to still be out on whether this is or was ever possible. Just seems weird that all these features aren't available across all these models the fragmentation is unbelievable.
Thread Starter #16
It did not work from me. I was told by the spreadsheet guys that it doesn't work on all 2020's for some unknown reason.
It will only work if the vehicle is equipped with it per the owners manual.
Kansas
2022 Rapid Red ST
I believe that required the vehicle to have the sun roof option.
Jeppo
Davidson County, NC
#20
