Auto Stop
Wingrider
Missouri
My new ST has about 1200 miles on it. The auto stop has ceased working correctly. Sometimes it does not come on at all at a stop, other times when it does come it, it shuts off before I touch brake/accelerator. I kind of have mixed feelings about this. I know some here have paid real money to get the damn thing not to engage. And I am not a big fan of this feature either. Should I go back to the dealer or be happy I got a "fix" for free?
Auto Start Stop only works in very specific conditions. Depending on brake input, weather, and other tiny things, for me it rarely operates. I don’t like it, I don’t think it’s something you’ll need to worry about or miss.
Chairborne Ranger
I've got about the same mileage as you do on my 2025 ST and have noticed variability in how the auto stop works when I forget to manually disable it. If I ease on the brakes coming to a stop it doesn't seem to engage auto stop vs. a more vigorous braking episode. If mine stopped working completely tomorrow I'd be just fine with it. You've got plenty of warranty time to get it repaired.
DaGooch
Illinois
I have a 2025 job1 ST and this feature was bothering me too. One thing I noticed, and maybe it is obvious to some, is that the stop/start feature turns off when I put it in Sport mode. The other modes leave it enabled by default.
I don’t think this is a problem, let alone anything that needs to be fixed.
JAX, FL
25 Explorer ST & 21 F150 PB
start car, buckle seat belt, turn off ASS, click ok a thousand times to get rid of the pop ups on the IC, put it in gear, crank the music, stomp the gas pedal, enjoy the drive.
Anderson, SC, USA
IGADawg96, after I hit the off buttons my warning crap goes away on its own. You are hitting OK for no reason.
SoCal
25 ST
I could be wrong but I think ASS isn't available until the vehicle reaches a certain operating temperature. That might be part of the inconsistency you're noticing
Battery state of charge has an impact on ASS. Try resetting the BMS.
That has kept mine working and my battery is 5.5 years old.
ExplorerSTLine
Pennsylvania
2025 Explorer ST-Line
My new ST...auto stop has ceased working correctly. Sometimes it does not come...
You might review (Owner's Manual) Page 190...
AUTO-START-STOP – FREQUENTLY ASKED QUESTIONS
Why does the engine not always stop when I expect it to?
The system is designed to work in a way that complements other vehicle systems, allowing them to operate at optimum performance. The system does not stop the engine if:
• The driver door is open.
• Your vehicle is at high altitude.
• The heated windshield is on.
• The engine is warming up.
• The outside temperature is too low or too high.
• The battery charge is low.
• The battery temperature is outside the optimal operating range.
• The engine is required to run to maintain interior climate and reduce fogging.
Why does the engine sometimes restart when I do not expect it to?
The system restarts the engine if:
• You switch the heated windshield on.
• You switch maximum defrost on.
• Your vehicle starts to roll downhill in neutral.
• The engine is required to run to maintain adequate brake system assistance.
Minneapolis, MN, USA
get the auto start/stop eliminator, and don't have to worry about it anymore
In confused why you’re saying press a thousand times to get rid of the pop ups.
This guys concern is that it isn’t working, instead of wishing it didn’t work.
JAX, FL
Press OK to get rip of pop up when disabling ASS, press OK again to get rip of pop up to hide seatbelt status. Same issue on our F150 when towing, every time there are pop ups about reverse braking not working and other obvious idiot lights and warnings. A "thousand" is an exaggeration, but the point remains that the pop ups are annoying.
Knew you were exaggerating, but what I meant was why do you push the butttons to dismiss the pop ups? Mine doesn’t show seatbelt status every time I turn on the vehicle, and the ASS pop up goes away by itself and pretty quickly. Even then just one push of the button and it doesn’t pop up the whole rest of the key cycle.
JAX, FL
Do you have a 2025 ?
JAX, FL
On the 2025, yes the ASS pop up will disappear if I buckle the seat belt after disabling it and the seat belt pop up will disappear after about 100 yards of driving each key start, but they are both annoying.
