Black emblems
Detroit, MI, USA
I know I saw this on here somewhere, can’t find it now. Want to get black ford emblems and cannot find them, anyone help? Thanks!
CoastieN70
U.S. Coast Guard Veteran
Travelers Rest, SC, USA
DoingOK
Smithfield, Virginia, USA
Just be careful installing the Etsy decals. I got lucky and mine went on pretty straight and I slowly worked from the middle out to make sure there were no wrinkles. Just take your time.
CoastieN70
The small rear decal was easy BUT the much larger Front Decal was a bear! I wound up using a heat gun (on LOW setting) to help smooth it out. I was 98% effective installing the front but you have to look close to see my oops...
Austin, TX, USA
The decal overlays aren’t hard to install, you just have to go slow. That’s what I have. To be honest, even though it’s a little more work... I’d just buy the whole black emblem that you have to replace with the original if you want it glossy and it will hold up better over time. You won’t have to worry about bubbles or the longevity of it.
DoingOK
I'll see how these hold up.....and grab the black emblems if they dont.
