25 Agate Black Metallic
St. Louis
Off the top of my head, I believe Ford removed the BOVs in 21 or 22.
SoCal
25 ST
Following this thread.....just got me an Agate 25. Excellent work man! IMG_3463.jpg
L
Ldstang50
FL
Thread Starter #23
FenFab black billet emblems. Soooooo much better looking
L
Ldstang50
FL
Thread Starter #24
Engine bay pics. Pardon the dust
To work with the aFe intake, Brett made his hotside piping cross OVER the intake manifold. The stock piping runs in-front of the motor and under the intake.
This threw me for a massive loop (ontop of the BOV) as I couldn’t figure out how to route the new pipes. The y-pipe is essentially flipped in directional travel. It wasn’t until I went to his website and looked more carefully at his installed pics that I figured out the new routes
He did a phenomenal job running it right behind the strutbar. It doesn’t touch anything. The aFe driver’s side intake and cold side pipe come awfully close to touching.
Ran the car pretty hard on my way to Tampa today. All highway pulls 50-90 or so. No boost leaks, no CEL.
BBK on order. Gotta fill up the bigger wheels and more brake exposure
L
Ldstang50
FL
Thread Starter #25
A quick note, silicone couplers can be notoriously difficult to slide over metal piping. I initially sprayed WD40 to get them to fit, but then I thought back to my Evo days, use hairspray. It’s initially slippery allowing the coupler to slide into place, but then gets sticky ensuring a sealed fit.
L
Ldstang50
FL
Thread Starter #26
Side-by-side comparison of my car to a stock Explorer, mainly the ride height. You forget how tall these are stock after you lower them. This was a nice visual reminder of the massive, positive change
L
Ldstang50
FL
Thread Starter #27
This is a reminder to everyone to get their car aligned ASAP after installing lower springs. I dropped the subframe, but on reinstall, you can see how the thrust angle and rear toe were way off. This has practically destroyed my rear tires.
This is after about 500mi
See below pics. The thrust angle and toe had the rear dragging across the ground. The car was barely controllable changing lanes.
i don’t have the camber I want, so I’m considering camber bolts or even control arms
Illinois
#28
View attachment 28238 View attachment 28239 View attachment 28240
How about the Oil fill? Is there room, it looks really tight from these pics.
L
Ldstang50
FL
Thread Starter #29
Just have to work around the strut bar, but that's easy to remove
L
Ldstang50
FL
Thread Starter #30
Superforged BBK done! If they come out with bigger rotors, I might purchase them. Even the 400mm doesn't fill-up the wheels
