Which app is everyone using for 0-60 and dyno?
KY
Just curious what app are you all using for 0-60 and or dyno results.
I know the apps are not concrete data but should give you a ballpark range.
LokiWolf
Henrico, VA
Dragy, which is an app and hardware solution.
No others are worth the trouble, because they are inherently inaccurate...
You need a Dragy or you’re just wasting your time. No phone app is even close. The refresh rate on a phone gps is 1hz. A Dragy is 10hz.
