It will probably drop your MPG’s a bit in the city and stop and go. It holds the gears longer for quick acceleration if you mash the gas. Doesn’t use all the gears until you get up to highway speeds
The Instructors at the ST Experience told us that the truck will always protect itself. Even in manual mode. Even shifting while in drive. Kinda idiot proof. Which is a good thing.
I've pressed the manual button while crusing at highway speed and it will be in 10th gear in all modes just upshifts earlier in Eco, then later in Normal, then even later in Sport and Tow mode.
