Depends what mode you're in. If you're in Sport mode, the gear number will show inside the digital tachometer. I think this is true for Tow/Haul mode as well, and it may be true for the offroad mode(s), which I've never touched. If you're in Normal or Eco mode, it will only show what gear you're in if you try up/downshifting with the paddle shifters.
