Black staining on exhaust pipe at downpipe and Y-pipe connections.
Oregon City, OR, USA
I started noticing black staining on my driveway. I found it's caused by moisture carrying black soot out of the joints at the downpipe and Y-pipe connections. I also see it coming out the drain holes in the mufflers(not pictured). I do have a tune. Any ideas what is causing moisture to do this?
Every exhaust does this…just most of them are sealed up so it doesn’t leak out that bad. Your clamps either aren’t tight enough or just suck.
ARC
Oak Lawn, IL, USA
2022 ST Black
Good reason to replace now with a better exhaust. Preferably something that is 2.5in and drop the weight of the stock system.
