Oil change
I did my first oil change at 974 miles I used Castrol Edge advance full synthetic oil.
I seen that a lot of owners use mobile 1.
I hope I didn’t make a mistake everything seems to be running correctly… will see in the long run.
JohnE
Vancouver, WA, USA
You’ll be fine. Just stick to the same oil if you can.
