I’ve been testing this along with several others and it’s up for pre-order at ID Speed now. Nothing else on the market is even close in quality or function. This was designed to closely mimic the oem 4 bolt subframe…not just bolt on and be there with your fingers crossed. It costs more but the differences when compared to the other options are pretty obvious. ID has pre-order pricing with the code No Fear.
https://idspeedshop.com/id-speed-2020-explorer-st-rear-diff-brace/
The pics are of pre-production parts that were raw, not anodized. Note they supply longer bolts for full thread engagement instead is reusing the stock bolts which IMHO are too short after adding the brace with spacers built in. This thing is as solid as it gets. And if you race a lot and want some extra peace of mind with a 4 bolt sub-frame it fits those as well giving you 5 mounting points.
- 8
- Show All
