Anyone else find the GPS worthless?
Oregon
I swear the only thing the GPS is good for programing in your home address.
Cleveland, Ohio
The irony of Ford blocking us from using gps while in drive, and yet they have no continuous seat belt chime. Ford is way behind on tech. Let me use the gps when I want.
I have always been able to just talk ti Siri. The Ford GPS must need it worded in a certain way because Ive never been able to voice command it. Abandoned it early on.
CA
I haven't used the stock GPS. Any time I'm driving my phone is plugged in so I get Google.
My 2011 F350 turns the radio off if I don't have a seatbelt on for an extended amount of time while the truck is in motion. Recently found this out when was driving around a customer's yard looking for a broken overhead line.
CareerFiremanGuy
It's gotta be a CYA thing ...
bigcat1185
Oregon
I use CarPlay in my truck, but Waze is always glitchy.
N. Florida
I strongly disagree. The GPS in mine worked better than great on a 2,600 mile road trip. It took us around nasty traffic, an over-an-hour wreck tie-up, construction delays and other such aggravations. BTW, NEVER put your home address in the GPS. Program a nearby gas station, intersection or well-lit parking lot.
bigcat1185
Oregon
I guess I should have clarified. Trying to get the GPS to recognize a destination is a nightmare. If you are able to get the GPS to accept the destination, it works great.
FORZDA3
Gloucester, VA, USA
Welp, mine works perfectly. It’s so good the wife can use it with no problems and that is saying a lot! The worst I’ve ever used is Toyota. We also have a 2016 Prius for the wife…
Cleveland, Ohio
Larger round of updates on my other car today. 13 categories. Small but helpful improvement to the navigation. Hoping Ford has the same culture of continuous improvement and software updates. No restrictions on using nav while driving either (just in reverse for obvious reasons).
Buck Nutz
Willoughby, Ohio
2021 Ford Explorer ST
I think Synch Navigation is pretty damn good. I only find issues when a hotel might be on a service road in a retail area and does not want to appear. At that point I used Android auto google map
N. Florida
We've not even had that problem. We can set to a city or a specific address without any aggravation. It even took us through back-streets to our hotel in Arlington, VA. We didn't have to deal with DC traffic much at all. I had been dreading tangling with it.
FORZDA3
Gloucester, VA, USA
You can use FORScan to change the country code to eliminate all the “attempts” at idiot-proofing in the US
My previous ride was a 2012 Jaguar XF supercharged. The GPS system wasn't laggy, it was glacial- as in unusable. Each part of an address accessed its hard drive to try to predict your input. Say you want 1143 Joe Blow ave. Type the first "1", and after a 5 second pause while it accessed its "database" for the thousands of addresses beginning with that number, showing the first 5 on the screen. Type the second "1" and it would do the same 5 second pause while it whittled the list down...and so forth. God forbid the address was in a different state, because that required a completely different database which was buried about 5 submenus down in a completely different area. Took me a couple months (really!) of frustration to find it. The couple of times I took the time to actually enter a location I got a pop-up telling me the roads weren't on the map! Owner's manual- worthless. Whoever programmed that crap was working on an emulator about 10,000 times faster than the processor in the car.
So, coming from that system- the NAV on the Ford is a wonder!
Jeppo
Davidson County, NC
Bioweapon Defense Mode? o_O
Cleveland, Ohio
In the event of bio warfare. Probably helps with nuclear fallout until you can get somewhere safer. Does something to seal up the car I think, but still keep you alive. They definitely are having fun with cars right?!
Jeppo
Davidson County, NC
Oh those kids at Ford. :ROFLMAO:
Waupun, WI, USA
The NAV was nice a couple weeks ago when I was in South Dakota with little to no cell phone coverage. Usually step #1 for me is plug my android in and googlemaps my destination, but without cell service that doesn't work too well!
Jeppo
Davidson County, NC
#20
Doesn’t downloading the area’s map to Google Maps solve that?
