Super Forged Big Brakes
Fremont CA
Has anyone installed, Super Forged Big Brake kit?
Several have but I’m not sure if they’re on here or not.
Average ST
Fremont CA
*Looking for color comparisons, I just ordered blue/black.
aholland86
AZ
zdubyadubya
Welcome to the club!
I do like the new kit with the integrated parking brake. The extra rear caliper is why I went a different route.
Average ST
Fremont CA
I like the wrap on your ST, huge difference on the white!! My next minor cosmtic is simply wrapping the blue between the rear door and the cargo in black, leaving the top blue.
Va
Curious of anyone has put the GT500 rotor and pads in the front like Ford has done with their performance demo unit. They told me it was a direct fit, with different wheels for clearance....
Yes people are doing it. No it’s not a direct fit…they lied about that.
There’s a guy in the High Performance Explorer ST FB group who makes and sells the caliper mounting bracket required to make it all work. Racing Brake sells the braided steel lines.
Chamorro85
Round Lake, IL USA
Wow nice color combo. Love the setup on both!
Bear, DE, USA
If I purchase the superforged kit with integrated ebrake do I need anything else for the install? brake lines etc? Or the kit covers everything required?
You should be reaching out to Bruce at SuperForged with questions like that. You’ll need fluid and I can’t recommend enough an M10-1.5 threading die if you’re swapping the brakes hoses.
Bear, DE, USA
Thanks looks like it does come with the lines included in the kit. I’ll grab a M10-1.5 threading die.
Why does one need a threading die? Does this imply the new hoses have ends that are blanks?
It’s very well known that the oem male ends tend to gall when you remove the rubber hoses. You have to chase the threads almost every time. Of every hose swap I’ve seen done online…every car needed the threads chased on at least one fitting. On my car it was all 4.
From the info presented in the thread, it appeared to me that the kit came with new lines. So that's why I was curious as to why you'd need a die. Now, if it's suggested to chase the threads I get it, but when a kit comes with lines, in my mind that includes the threaded ends- thus my question. I think other members might be curious about this as well.
