FENG - Fake Engine Noise Generator DELETE
Greyghost
Harleysville pa
Well, this kind of raises a question/issue I was having.
I do not understand Forscan or any of that, plan has been to just have PBD do the install. That said, would this mean they can disable things like FENG and the key fob double beep?
What would be on your list of "must turn on/off" if you had one chance to have someone do it for you?
1. Double honk key fob delete
2. Side mirror ST logo on with high beams while driving
3. Bluetooth iphone car sync connect (2020 Model)
4. FENG delete
5. Access to full screen mode all time (Nav, entertainment...)
6. Camera access while driving
7. INDEF run time from keyless start
am I missing anything? hahaha
Toadster
Folsom, CA
4. FENG delete
What’s #5 ?
And are you doing Bambi mode?
Greyghost
Harleysville pa
What’s #5 ?
This screen should be all map. The fact it is sectioned off for anything I am not using (audio in this case) is annoying. Seems like an obvious flaw.
Toadster
Folsom, CA
so #5 makes it 'all map'?
bp123
STL
Thanks for all who bothered to share the knowledge on this thread!
2023 Explorer ST - Process worked like a charm. Its no V8 but the genuine engine noise is so much more beautiful than the FENG... Can't believe I even had to do this crap Lol.
For anyone else still uncertain on the process - See below and attached picture. I opted to do it via the ACM Module Config menu instead of the coded style As-Built screen.
Firstly I found this video great because I also wanted to disable the double honk door chime as part of this process. But it also was a good video explanation of the process of hooking up Forscan, where to click, etc for the uninitiated.
powerboatr
Only real issue with disabling feng...is loss of active noise control
In my area tye high traction asphalt
Makes keeping anc enabled a plus
