You could have saved yourself a lot of hassle if you had done some reading or asked about wheel fit first. Your tire is too tall, that’s obvious. Now depending on wheel width and offset plus the tire that’s too big, when you put on the spacer it’s gonna rub the fenders HARD when you try to turn. At some point the best path forward is to back up and buy the right stuff.
Just for grins though what’s the wheel specs and tire size?
