Best plastic cleaner
Lincoln, CA, USA
For all the exterior plastic what seems to be the best cleaner and treatment?
I use 303 Protectant for all plastics inside. Currently using Gtechnique plastic treatment on the outside plastic. I use any generic citrus based cleaner to clean.
M
Lincoln, CA, USA
Thank for the info. i was trying to figure out something that worked.
KMEdell
Syosset NY
I was very impressed with the Exoforma Black Plastic Restorer, easy to apply and polish, made the trim look brand new!
Ontario
2020 explorer st
Cerakote is considered the gold standard. There is a good review on project farm if you like.
Link
OK ST
Edmond, OK, USA
https://aerolon.com/
I use this on the whole exterior and it keeps everything looking new. Have used it for years on other vehicles with black plastic exterior pieces and they continue to look like new. Easy application, I only apply in Spring and Fall and other than regular washing that's all I do to protect paint and plastics.
RTM
Richmond, VA
Do these remove the white clay residue from using a wax on the plastic inadvertently? I used the kit the dealer gave me and it made the plastic turn a whitish gray color. Ceramic was applied to the plastics too, so I assumed the wax would be fine on that. I tried NuVinyl, and another vinyl cleaner and it only lasts a few weeks at the most. Dealers service person told me to "steam it out". I have no clue how to go about that.
I saw a youtube video that used a white pencil eraser on the trim. I bought some and shockingly, it removed the rubbing compound that nothing would take off! Here is the eraser I am talking about:
https://a.co/d/0vGOEYO
RTM
Richmond, VA
This really works! It takes some elbow grease, but it does the job. This may be the best tip I've had on here. Thanks.
CERAKOTE and it's not close. Did a black trim project tonight with my old 123k mile X5 and very pleased w/ the results.
Will add pics tomorrow. *Couple pics added.
