Exhaust Sounds Through Speakers?
NewGuy
Active Duty U.S. Air Force
NY
2022 ST
Hmm
I would reset and try again
It worked perfect on my 23
Remove fake engine noiseACM727-01-01 xxxx xxxx 0xxx if first digit is 1, change to 0
see common on sheet below
https://docs.google.com/spreadsheet...ukfkgBqYkDE2w8imywaNF8VJF8/edit#gid=671029316
Thanks I'll try that, scared the hell out of me when I was visibly raising the volume and nothing was coming out. By chance, did you enable mirror down adjust when in reverse? I enabled, write and still didn't do it. Thanks again
powerboatr
No i have not
Let us know how the engine noise works out
A little off topic but I saw a show where they installed Borla external speakers and amp on an electric mustang. Sounds like a V8 of course. IMO that would be way to embarrassing to drive
Thread Starter #24
powerboatr
Yes it would.. all girls garage maybe.
No hotties on there anymore
sasa22
U.S. Coast Guard Veteran
iraq
ford
#27
Hello guys, can I activate the fake exhaust sound in a 4-cylinder Explorer like the Timberline and ST-Line? Thank you. My car is a 2020 XLT model. If I cannot, is there a way because of the annoying four-cylinder sound?
