Hi There I have an annoying problem of only 1/2 of screen does not load sometimes when I start the vehicle and the map loads, sometimes when I start the vehicle the whole map loads fine
and another time I only get 1/2 of the map loaded and the rest of the screen is light blue. If I try to change settings or map view or map preferences, nothing helps.... why does this happen?
Is there any way to get the map work properly. I'm not a computer guy....Also, sometimes the preset radio loads and other times when I start the vehicle the Sirius preset doesn't work and I don't get
Sirius to work unless I program it again manually. Weird?? What's the solution to these problems?
Thanks
Thanks
