FS 1 set Eibach pro spacer
Boonsboro, Maryland
brand new in box. taken out for pictures.
Part #: S90-4-30-057-B
30mm Pair (Black)
1 set. 2 spacers only.
sells for $211 brand new. Asking $125 + shipping. IMG_9145.jpeg IMG_9144.jpeg IMG_9143.jpeg
30mm Spacer / Bolt Pattern 5x114.3 / Hub Center 70.5 Spacers can only be used with wheels that have cut-outs (facing the hub) to clear the stock studs. Please check as follows: Original stud length (i.e. 35mm) minus spacer-thickness (i.e. 25mm) = 10mm excess stud length. The cut-out should have a depth of 11mm.
SmittysST
SOCAL
2023 FORD Explorer ST
will these work on factory wheels?
