2020 Ford Explorer ST Subframe Replacement
Illinois
Soon I will be replacing a subframe on a 2020 ford explorer st that i am working on. The car got into a accident and the subframe got damaged, so we are replacing it. Is there any info or videos that will be helpful for me while im working on it? Any info will help. I will be following the procedures that alldata says to do but i just want to know if there is anyone that has replaced a subframe on these cars before and if you have any tips. And do you really need to buy the $1500 engine hoist from ford to hold up the engine? or is there any other way to work around that?
I Bleed Ford Blue
23 Rapid Red Explorer ST
There's always the option of renting a cherry picker too, though I doubt it would be much cheaper than buying the Harbor Freight piece listed above.
San Francisco
2022 ST
I haven't tried before, but has anyone dropped it out the bottom before?
If so, and you know someone with a lift, you could be in business.
I Bleed Ford Blue
The problem with a cherry picker is the legs will be right under the subframe where you need to work.
San Francisco
2022 ST
Tripod with a block and tackle attached?
A
Illinois
A
Illinois
We have a lift at the shop so it shouldnt be too hard to do.
