2025 OEM 21" Winter Set-ups?
AMCfoxbody
East Coast
Hi folks, let's see those 21" OEM wheel and tire set-ups? I have just purchased some Velgen 22" wheels with 305/35/22 tires and am going to convert the OEM 21" wheels to a winter set-up. What I am looking for is the biggest/best size tire that will fit the OEM 21" wheel w/out rubbing, etc. I am also lowered on H&R springs. I want to size up the tire to a little beefier look for the winter. Any help or tips are appreciated. Thanks!
The Michelin X-Ice Snow is a nice tire with a beefier look. A 305/40R21 will give you a wider tire while keeping the same height.
On a side note, wider winter tires generally means worse traction than narrower tires. Having said that, if you like the look, go for it. I run 295/40R22 Michelin all seasons and get good traction in anything but deeper snow. We don’t get much in Chicagoland anymore. Handles 6 inches fine.
AMCfoxbody
AMCfoxbody
East Coast
This is true and you are correct, I appreciate the reminder - it is definitely a balance between style and function ;)
which Velgens and which tires did you go with?
AMCfoxbody
East Coast
I haven’t mounted them yet - waiting for the weather to turn better but went with Velgen 'Classic5 V2' Wheels in Gloss Bronze - 22x10.5 +30 with Lionhart LH-Five UHP All Season 305/35/ZR22 110W XL Tires.
