2025 ST, Fordpass & Google often disconnected from Ford network
California
2025 Ford Explorer ST
A little more info. I still have not taken to the dealer yet but it seems I lost the internet/connectivity section of the settings somehow. Which is supposed to be right below the "display" button and above the "911 Assist" button in the settings. I also found out that my lane centering is also not working, therefore my blue cruise is not working but regular cruise control is and it will slow and speed up depending on the car in front. So not sure what caused that but dealer will be seeing it next week. The only thing I have not done and do not want to do is the full factory reset because I do not want to have to re-enter everything including all my places/hotspot (which is also still working) all over again, but we will see what the dealer does. Kind of weird how this all rear its head out of the blue but I guess that's technology for ya. I'll post more after the dealer looks at it in case any of you go through this in the future.
St. Louis
2025 St Line
Having the same issue. I've had my ST Line for three weeks. It is completely random when the issue pops up and is very annoying for sure.
California
Dealer took 5 hours to fix my 2025 Explorer ST but here is what they did (see picture) They did not give me any reason as to why it happened just that sometimes it does which is not very reassuring. Anyway if the internet section disappears from your vehicle settings I believe the button/section is under the one that says "Display" and above the "911" section in-between those two, so if your vehicle looses communication and that WIFI/connectivity button disappears then at least you know what will need to be done at the dealer. For now mine seems to have been fixed (knock on wood) Ford Work Order.jpg
California
Ok wow! I did not know that picture would come out that big my apologies if it bothers anyone. By the way if anyone knows what the CMR and PCM is let me know I get the GWM is gateway module and the TCU is the Telematic Control Unit but not sure exactly what the PCM is and the CMR is, so if anyone can elaborate that would be awesome.
T
Tolum
Quebec City, QC, Canada
Thread Starter #25
Ok guys, an UPDATE shows up this morning on my screen and the car is connected to the Ford network. Hope it's the good one this time....
Translation:
Improved Connectivity and Location Services. This update improves the vehicle's ability to maintain connectivity and location services.
Telematics Control Module
California
That was an update from a few days ago. Unfortunately for me I think my car either got stuck on that update which caused my problems or my car screwed up before they released that. Hopefully that update keeps ya from having the errors I did.
Ct
25 ST
#27
After about 3 weeks of working mine is giving me problems.
As others mentioned, no connection to ford app, google etc.
Is this definitely a dealer item or has someone found a reset procedure?
Thanks.
TJ.
T
Tolum
Thread Starter #28
I would say, since the Feb. 22 update above, mine is working flawlessly.
Ct
25 ST
#29
Yours was OTA? If there’s problems with connectivity then I’m not sure if i’ll get it….??
T
Tolum
Thread Starter #30
If you scroll up you'll see that since December, I had intermittent connection problem with the Ford cellular network. I would say more often offline than online. Did bring the car to the dealer for a 48 hours re-programming, works for 1 week and failed. Finally on Feb 22, when getting in my car in the Costco parking lot, I saw a note on my screen saying that a new update have been done. Got that update over the Ford network even if I wasn't connect to it. Since then, no problem, never been disconnected. So maybe use your screen and look to the update section to see when the last one happens. If you have a February 2025 update, you should be good.
Karolis
North battleford Saskatchewan
2025 Ford explorer ST
#31
Are you talking about the February security update?
