21 ST in the CLE
I Bleed Ford Blue
I Bleed Ford Blue
23 Rapid Red Explorer ST
Thread Starter #41
I just looked at tire rack and the factory 20" tire lists at 34 lbs a tire and the 22's I put on are at 37 lbs per tire. I then took the scale out side and the factory 20's still mounted with sensors and center caps weigh in at 70.2 lbs per corner. I only weighed one just to get an idea.
Today I took my 22's off and put the 20's back on. I weighed one before I put them away in the wall rack. The 22's weigh in at 75.8 lbs. That's 5.6 lbs per corner, so 22.4 lbs total.
I Bleed Ford Blue
I Bleed Ford Blue
Thread Starter #42
Yesterday on my way to work I made a small detour to my favorite mexican road. It was a cold dry morning so I thought I might get a good run. I got a 12.38@109.14 with a D/A of negative 1112' on 92 octane E10. I also managed a 3.95 0-60 on the same run.
I was inspired by my first sub 4 second 0-60 so since I needed gas anyway I filled up with an E30 mix. If the weather is dry tomorrow morning I'll try again. I now have the lighter 20's on with E30 in the tank and cool enough weather, I'm hoping for 12.0h's at about 111-112 and maybe a 3.90 0-60
I Bleed Ford Blue
I Bleed Ford Blue
Thread Starter #43
I was sitting around doing nothing so I checked the weather and decided to go try another run. With a temp of 37 degrees and a D/A of negative 700 ft and an E30 mix I pulled off a 12.09@112.30 and a 0-60 of 3.75!!
